Use this procedure for the following tasks:
  • Display the digital certificate for a certificate type or list all the certificate details from the local store.
  • Display the certificate authority (CA) details for a trustpoint CA name or list all the CA details from the local store if the CA name is not specified.
  • Display the configured key details for a key name.
  • Display the configured subject details.
  1. Enter Fabric IPsec Gateway Configuration mode:
    enable
    virtual-service WORD<1-128> console
    Type CTRL+Y to exit the console.
  2. Display all digital certificates:
    show certificates all
  3. Display the CA details:
    show certificates cacert [<ca-label>]
  4. Display Certificate Revocation List (CRL) certificate details:
    show certificates crl [<ca-label>]
  5. Display the certificate signing request (CSR) details:
    show certificates csr [<ca-label>]
  6. Display the name and public key of all the key-pairs:
    show certificates keys
  7. Display the details of signed certificates:
    show certificates signed [<ca-label>]
Switch:1>enable
Switch:1#virtual-service FIGW console
FIGW>show certificates keys key_rsa
Key Label: 	key_rsa
private key with:
pubkey:    RSA 2048 bits
keyid:     ef:4c:1d:a7:cc:84:6f:87:da:e4:de:99:07:3d:96:fc:9a:d1:c9:f4
subjkey:   cb:d1:67:a0:da:9c:05:ce:c0:0d:a3:5c:1b:ba:ce:3f:ff:af:8f:77
The following table defines parameters for the show certificates command.
Variable
Value
ca <ca-label>
Specifies the name of the certificate authority (CA).
If you do not specify the name, the command displays the details of all configured CAs.
